Mega Purge (revised)
Price: $100
Description:
How  does this stuff accumulate so fast!  I will delete items as they are sold and add a few that I've missed.  PM with questions etc.  First PMs will get priority on purchases.  If you are considering a large item, also consider small items to reduce the shipping costs per item.  I am shipping from Canada so shipping will be a little more costly and travel time can hit upto 2 weeks.
All prices in US dollars.
B Pillar Moulding - 51711819817 Used, some scratches $30
Clutch Slave Cylinder - Used with Rod and Hose  $70
Distributor Housing  - Cleaned, honed, and clearcoated  $35
Halfshaft Boots - $5 All
Horn Set - Cheap replicas new  $10 Set
Odds n Ends (Single Picture)
Headlight (socket) dust covers $5 set
M10 Engine Front Lift Plate - plated  $5 SOLD
Hex Bolts  - For Halfshafts  - plated $5 per 12 SOLD
Plug Wire Guides  - Prototype  plated $5 set SOLD
Cable Loop - 64531353270  - plated, requires  rubber grommet $5 ea
O²  Sensor Bung and Cap Bolt  New $20 SOLD
Crankshaft Nut and Washer Sets - plated $5 set
Dipstick Tube (Early non-flared) With Cable Loop $10 SOLD
Back Up Light Switch (Getrag 242)  Tested good $5
Engine Temp Sensor - Tested good $2 SOLD
Hood Rubber Seal - used but clean SOLD
Seat Pad (Driver side) - Used 3 years, great spare  $140
Tii Coolant Pipe - Can`t  guarantee quality.  May have pin holes.  $20
Tii Intermediate Shaft  - Early,  plated, modified, funky  $20
Tii Plastic KF Belt Covers Set - funky $10
Tii Throttle Body - New rod bushings - $300
Edited by PaulTWinterton
Hi Paul,
I'll take the below - if you still have them shipped to 98077, just let me know how much!
Dipstick Tube  $10
Tii Intermediate Shaft - Late, plated $30
Tii Linkage Pivot - Powdercoated and plated.  New shims. $50
Crank Pulley - Powdercoated and painted timing marks $30
Thanks,
Bret
Edited by Rodolfo Lasparri
