1975 BMW 2002 Race Car For Sale
Price: $17000
Description:
1975 BMW 2002  Vintage race car. The car was raced by the previous owner with Midwest Council for the ten years, and it is believed the car was purchased by current owner in 2011. Believed no major accidents with the car. The car was built by previous owner to SCCA ITB specs and car was also raced in vintage and production classes. Car is presently set up for vintage racing.
Recent motor rebuild. The engine is 9.5:1 compression and is happy with 93 octane.
Engine specs: Coated rod and main bearings standard size, new oil pump. H beam connecting rods, Je forged pistons and Je rings, urethane motor and trans mounts, 2.0L crankshaft, mls head gasket, heavy duty rocker arms from Ireland engineering. Rocker locks instead of springs. 292 duration cam, Solex side draft carb.
Car has Ireland suspension Coil-overs front #450 spring and #400 rear, Electronic Ignition, Six point cage, Custom brake ducts, 4.10 welded diff, Metric Mech. transmission, Spares include: Two extra heads, 3.90 welded diff, Engine core, Ivey weber 32/36 carb and intake, two extra sets of wheels. OEM Brakes.
Email: Brent.mosing1@gmail.com for more information or pictures. Also have receipts from work done for last owner.
videos
Dyno Time
https://youtu.be/4eAcaGmLGt0
2002 BMW Burnout
https://youtu.be/Oie7FF7BXek
2002 BMW M10 Crankcase Vent
https://youtu.be/Hg_NzsUmVck
2002 BMW M10 Throttle Response
https://youtube.com/shorts/d2js04T0miA?feature=share
2002 BMW M10 Fresh Build
https://youtube.com/shorts/EWdnVLcDWD8?feature=share
2002 BMW M10 Timing Set and Running
https://youtu.be/hsIdpCSxtKw
2002 BMW M10 First Start
https://youtu.be/B0cfTHaPX3U
2002 BMW M10 Build
https://youtu.be/doxggZaFwt0
2002 BMW M10 JE Pistons Clearance Issues
https://youtu.be/jG7TSV6nqlY
2002 BMW M10 With JE Pistons
https://youtu.be/7AYyeTbyFeI
2002 BMW M10 Build
https://youtu.be/rJOvP2BQ-tU
2002 BMW M10 Build
https://youtu.be/g8LjfF0nkoQ
Edited by bmosing
Correction on side draft carburetors, OEM Brakes and "built to SCCA spec", added pic of the scale for weight, no driver
nice!!!
write up says 32/36 weber, but pictures clearly show dual sidedrafts.  might want to be clear on current configuration.  32/36 would have been SCCA spec which the car has clearly been modified far beyond legality in that class.  sidedrafts would be FP/vintage spec.
stock brakes still?
great vintage race car!
