1975 BMW 2002 For Sale
  • 5 speed conversion with request shortened drive shaft, proper mounts
Motor:
  • Fresh (>200 mile) complete rebuild.  Stock compression .10 over, all gaskets, etc. (still on break in oil)
  • 292 Cam
  • Aluminum Flywheel (Massive improvement to stock, very revvy)
  • Weber 40 downdraft (yes, a single 40) which was a bear to find but wakes it up nicely and doesn't complicate tuning duals.  Fresh rebuild (>500 miles) from Top End Performance
  • Canon Intake which was opened up
  • Ansa Sport center and rear double tip exhaust
  • Ireland Engineering radiator
  • Electric fan
  • Water tube bypass to heater (due to intake manifold)
  • Fresh Thermostat, plugs, wires
  • Bluetooth enabled programmable distributor
  • Smog Delete
  • Silicon hoses throughout
Suspension
  • Yokohama S Drives on Rotas (Panasport clones) -- 1k miles on both
  • Coilover suspension in front, lowering springs in rear yielding a 2" drop
  • 22mm front sway, 19mm rear
  • urethane bushings throughout front subframe
Brakes
  • Volvo big brake conversion in front, stainless hoses
Interior
  • Heater box rebuilt with fresh blower motor
  • Custom center console (see "Electronics")
  • New wood steering wheel, shift knob
  • New carpet kit
  • E34 rear seats
  • Period correct Recaros refinished in black watch plaid with proper mounting adaptors
  • Sound insulation under carpets
Electronics
  • H4 headlights
  • Custom center console which needs final wiring through the bulkhead including VDO gauges, hidden bluetooth stereo, Carling switches for front and rear fogs
  • Hella 500 driving lights (need to be wired, see above)
  • Battery relocated to trunk
Exterior
  • All major rust abated
  • Repainted in Amazon Green
  • Belt trim delete with holes welded
  • Sunroof functions
