Door Check Bracket OEM Style - Revision 2
Price: $70
Description:
We now have a revised version of our door check bracket, however this time closer to the OEM style. This version is  a zinc plated, one-piece reinforcement/repair bracket that's internally mounted, held by 2 allen bolts. It's an easy installation process which doesn't require welding, and no cutting of the panel. However, you will need to remove the broken piece(s) completely that are left inside the A pillar (Unless it's been removed by itself from the tack weld). An attached guide rod makes it easy to install through the slots and will be removed once installation is completed. All hardware is included. Please specify left or right side(s). To purchase, please visit our website at https://prdesignsf.com.
Cost is $70 per side, or $125 for a set of left & right; shipping is separate (will need to calculate to your ZIP).
Thanks!
