123 Tune Distributor
I believe you can program the curves you want from either a desktop or a laptop
The advantage of the laptop is you road test each curve you program  to find the one that runs the best
If you tell me your build, I will install the mechanical and vacuum curves that  should work well and you can adjust from there Actually I will put two curves in it
  • 1 month later...
