Posi-lock vs Eccentric for rear camber and toe adjustment
I have the Posi lock version on the race car. The adjustment technique is very different. The eccentrics are a matter of turning a bolt head and tightening the nut. Pretty basic. The Posi, you leave both sides slack and move the control arm against tension with a long pry bar between the subframe and the control arm bushing, then tighten the through-bolt. It takes a little more finesse with the Posi, but I think your range of adjustment is greater than the eccentric. Choose your poison, I guess.
23 hours ago, Mike G said:
I was told eccentric for toe and posi for camber is ideal. Posi is less likely to move, eccentric allows finer tuning.
I might have said that.
It makes sense-- So, wait, maybe not.
Likewise, I've got homemade wrenches for adjustment.
  • Haha 1
