Fluid level in clear CV boots
I just had the gear oil changed in my old-style boots. I told the guy 180cc in each but I don’t know, he may have overfilled them slightly.
Below are photos of the recent change on Friday, and the last time three or so years ago (boot is cleaner). Can there be a problem if these boots are overfilled a bit? I wouldn’t think so but thought it best to ask:
Edited by kiva667
1967 2000 #1326213 SOLD / 1972 2002 Verona - insurance loss / 1962 700 Luxus SOLD / 1975 530i Malaga SOLD
http://nk2000project.blogspot.com/
"Rust Never Sleeps"
I in no way want to put this on you, but did you ask the shop if they have the capability of measuring and dispensing a metric volume like that? Many shops do not have easy access to metric volume measuring and dispensing devices. Did you tell them it is also 6.08 ounces?
I have a few syringes for removing and dispensing fluids such as brake fluid and oils, but most do not. I use ones similar to these. A standard metric silicone vacuum hose threads right on the end as well as the supplied clear hose.
200ml Luer Lock Syringe with 40 inch Tube and 18Ga 20Ga Needle (2 Pack 200ml/cc Luer Lock) https://www.amazon.com/dp/B083GPD3NB/ref=cm_sw_r_cp_api_glt_fabc_WCQJ3G8BP6HMREFW5WZ4
Edited by tjones02
Tom Jones
Thanks, Tom
in Canada everything is metric and my guy assured me beforehand he could measure accurately. I guess the question remains, should I drain a bit of oil from the boots or is it ok to leave as is.
Kit
"Rust Never Sleeps"
My next question is, are you sure the axle angle is the same in both photos? The fluid level could look very different if the axle is at a different level. That said, I wouldn’t worry about it unless it starts leaking.
Tom Jones
it’s hard to tell but I think the car was up on a lift when the first pic was taken and in the photo from today the car was parked.  Yes, different angle, different perspective.
Anyhow I’ve run the car quite a bit in the few days since the gear oil was refreshed and no leaks at all, so I will put the matter to rest.
"Rust Never Sleeps"
