do we have a bad starter?
esty
we wired the 72 as we've been discussing here in another thread...we ran a wire from fuse 12 to Coil + terminal…it is powered when the key in on
there is 12 at starter via the batter cable...the small wires to solenoid go back to fuses that are hot when the key is turned to the start position…I believe that is how it should be
the starter will not move, the solenoid will not spin…we tried jumping from the battery + to the solenoid and got nothing...solenoid should click, spin or do something...right?  ground cable from battery to engine block is solid
 Sounds like the solenoid is bad you should hear the electromagnet actuate or at least feel it move if not something is wrong with the solenoid, are there 2 small wire terminals on your solenoid if so try moving the small wire to the other one, if still no go try (carefully) shorting the 2 large battery connections together with a large screw driver the starter motor should spin verifying that the solenoid is bad.
Edited by Son of Marty
George S Patton
we did all of that...
when we 1st hooked things up and turned the key we got a couple of small, faint clicks  from the solenoid and nothing since
seems to me if the solenoid is good we should be able to lay the starter on the ground, connect a battery to the starter then jump the battery post on the starter to the solenoid and get a spin
What is your voltage across the battery? Also measure your voltage at the starter to a body ground and between the 2 high amp connections on the starter, 12v+ at all points? if so obviously the starter should try to rotate. Do you have a spare starter?
George S Patton
If you jumped from a good battery source, probably yes...
Unless the starter has a crappy path to ground, got a good path from the engine to chassis to negative batt terminal? Negative batt terminal clean and tight?
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
4 minutes ago, esty said:
i have 2 older starters that i don't remember where they came from... we're going to try it tomorrow and see what happens
Bench test them before replacement. Lot easier
76 2002 Sienabraun
2015 BMW F10
Quick way to pinpoint a bad starter vs a weak battery:  turn the headlights on, and turn the key to start.  If the headlights dim, then the starter is trying to work because it's drawing current, and the problem may be a weak battery or poor connections somewhere.  If the lights stay bright, then the starter either isn't getting current at all, or it's not functioning.
Steve was out at daybreak this morning, working on getting the car to crank...he took the starter off, bench tested it and it checked out as good..he put it back on the car, turned the key and magic...the motor started turning, he turned the key again, starter spun engine then a spark and the starter stopped...he is right back to where he started
it's strange that putting power to the starter on the car and jumping the solenoid pin directly from the battery does not excite the solenoid...the small wires to the solenoid are hot when turning the key to the start position
i suggested that he put the other starter on, he bench tested it and it is good on the table (but so was the one on the car now)...he remembers that starter worked and was pulled from the 76 to installed a M3 starter
my money is on a bad starter...even though it check out as good out of the car
my money is on the the ground strap, if they work on the bench and not in the car.
Tom
edit -- assuming you are  using the same battery.
Edited by '76mintgrün'02
I'm with Tom on the bad ground if the solenoid doesn't energize.
To check for a bad ground (block to battery), try connecting a jumper cable from the block directly to the - battery post and then trying the starter.  Or, one of you turn the key to start while the other puts a finger on the carburetor linkage.  Absent a good ground, the carb linkage is the ground path for current, and will quickly get hot when starter amperage is applied to it.
Mike...i laughed when i read your last post and the several above it...i was getting ready to say mystery solved...steve figured out a bad ground by connected a battery cable to the block next to the starter and the negative battery terminal and it spins...it turns slow with a full battery which could suggest that starter we took off of the 76 is bad...when the engine turned yesterday with the 1st battery it was spinning normally
right now the ground is from the side of engine block to battery with the small leg going to the fender...he's adding another ground strap from one of the starter bolts to the side of the battery
next adventure will be spark and fuel
