BEHR AC cooling fan pictures needed edit BOSCH fan
PatAllen
Hi, i would like to know if someone has pictures of how the original BOSCH AC cooling fan mounts to/how.
looks like it is held on the hood hinges with some brackets.
just want to see/know.
thanks.
Edited by PatAllen
wrong fan brand
1985 XR4TI, 22psi ±300hp
  • PatAllen changed the title to BEHR AC cooling fan pictures needed edit BOSCH fan
Pat,
The Behr (Bosch) auxiliary fan bolts to the Behr condenser with four brackets, two longer brackets at the top of the condenser and two shorter brackets near the middle of the condenser. Below are a couple photos of the fan with the condenser. And then, the combined condenser-fan assembly bolts to the radiator supports with four more brackets, two shorter, two longer.
Here are the factory installation directions:
https://bmw2002tii.nl/wp-content/uploads/behr-airconditioning-installatie-handleiding-bmw-2002.pdf
Sub-section g. and illustrations 14. and 15. describe the installation of the condenser and auxiliary fan.
Best regards,
i have the same condensor but the brackets are significantly different hence my request to see pictures.
after investigation mine bolts really to the hood hinge...
tbc
My Behr fan has those two attachments Steve shows to the condensor (C-shaped at top, short straight at center), but it also has a longer L-shaped attachment bracket BELOW those two (see open hole in fan in Steve’s last pic) that attaches to the front of the hood support brackets. They look just like the slotted L-brackets in Pat’s pic…
Tom
Edited by visionaut
Where we goin’? … I’ll drive…
Tom
Thank you, Tom,
Yes, as noted, there are four brackets tying together the condenser and the fan, and four more brackets tying the condenser to the hood hinge braces — but I don’t have a personal photo of the latter. The illustration 15. I referenced, in the installation manual I attached, does show the brackets from condenser to the hood braces. I’ve been trying to find a working link to the Behr parts manual; it might show an exploded view as well as all the parts numbers. (The Behr manuals long hosted by the tii register are no longer available.)
Best regards,
From the Behr parts manual, the brackets attaching the condenser to the hood hinge braces are shown in the first photo below, circled in red. And, not that I had any idea about this previously, the brackets changed for the 1975 model year, presumably continuing through the 1976 model year (the parts manual is a 1975 version). The second photo shows the parts numbers: “before 1975” and “after 1974”.
I’d return to the installation manual for a more useful view!
Best regards,
the picture i showed are from an existing cooling fan i own that i plan to install on my automatic 02. i have the condenser somewhere too but i would like to see an actual existing set up because i have conflicting information and some missing parts.
thanks for the detailed diagrams.
regards, Pat Allen
