Is the crown nut on the drive flange reverse threaded?
Is the crown nut (#9) reversed threaded? Killing myself trying to get it off. Impact gun has nothing on this #*^(@$!  Of course I made it infinitely harder by taking the subframe off before loosening the dang thing
Side shaft/wheel bearings
Every so often (one in maybe 6)
those things will friction weld themselves in place.
At which point, you get to cut them off.
I recall that when I rebuilt my rear subframe the torque specification of that nut was 300 ftlbs, IIRC.  I made a 4 foot breaker bar to tighten it.  You could try the same with a 4' piece of 2" steel pipe and a 1/2" drive regular 18" breaker bar inside the pipe.
Edit: a 3/4" drive breaker bar would be stronger.
If you don't own a breaker bar, they're nice to have.  They come in handy quite often with old cars.
Edited by PaulTWinterton
I broke a cheap 1/2" hinge handle breaker bar trying to loosen one of those nuts on an old VW.  They get put on at 300 ft#, (or 250, or whatever the book says) but if they are stuck it can take a lot more than that to remove them.  I have a 3/4" bar now and can jump on it with confidence.  I took this photo at the wrecking yard when I was considering swapping in e21 drums/brakes, but once I saw a bunch of dirty old parts inside I decided to just stick with what I have.  I welded the angle iron onto an old drum to keep it from spinning, since they pull the wheels off of the car.  I got scolded for bringing the jack and lifting it up.  It was still fun.
