Hello Iam trying to find my original paint color on a 1976  2002  ser, #2393158  .   I emailed info.grouparchiv but they are in the process of relocating . Any help would be appreciated. Thank you
20 minutes ago, esty said:
if it hasn't been stripped already, remove a door card or rear panel and see what color lurks behind them
+1
And if those areas have already been re-painted, look way up under the dash!
Your choices are shown below: the exterior-interior color concordance from February 1976.
What color is your interior currently? A few good photos of your car, including the interior, engine compartment, trunk, and underside can suggest to us the original color. Unless it’s had a very very thorough re-paint, there are usually hints…
VIN 2393158 is a June or July 1976 2002A, very close to the end of 2002A production, which ended with VIN 2393292.
1 hour ago, geok555 said:
… Steve mentioned it was a 2002a does the a mean automatic trans….
Yes, all the 239xxxx cars were 1976 model U.S.-spec 2002 automatics. The driveline tunnel on the automatics was a tad wider — to accommodate the automatic trans — making them able to fit the e21 overdrive 5-speed without applying a BFH in the vicinity of the accelerator pedal.
Below is the entry of the VIN decoder offered by the BMW 2002 Car Club of Columbia. It’s accurate but lacks the build date specificity of the Archives report, as well as the exterior color provided by Archives.
if you want a definitive color for the car,
in most cases, even the best body shops
do not take the vertical "B" pillar aluminum
off the cars because it is attached with
rivets. under that is always an unfaded example
of the original color.
stone
