  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
It's not much but it'll be a nice car one of these days
Koogleworks front.
Posted Images
11 hours ago, Son of Marty said:
Technically in the front it a air dam, spoilers are fitted to the rear of a car.😉
Three different definitions
:spoiler is an automotive aerodynamic device whose intended design function is to 'spoil' unfavorable air movement across a body of a vehicle in motion, usually described as turbulence or drag. Spoilers on the front of a vehicle are often called air dams.
spoiler is an object which forms part of an aircraft's wings or part of the body of a car. It changes the flow of air around the vehicle, allowing an aircraft to change direction or making a car's forward movement more efficient.
Automobiles
a similar device for changing the airflow past a moving vehicle, often having the form of a transverse fin or blade mounted at the front or rear to reduce lift and increase traction at high speeds
21 hours ago, halboyles said:
Full body kit on our '71 1600.  Custom formed by the PO out of solid steel.
It seems like sheet metal would have been a much simpler choice, not to mention the weight !
I think I misrepresented the construction.  What I meant to imply was that it was all sheet metal not fiberglass or bondo.
  • Haha 1
