Long term storage of a transmission
I picked up a spare 5 speed last year just in case I might need another.  I cleaned up the exterior, drained the oil. and put in some 90 wt oil that I had left over from my VW transaxle. I don't think I refilled it all the way since I ran out of oil, so I'm wondering if there's anything I should know about best practices for long term storage. Should I just fill it up normally, or tilt it and overfill it?  Or even store dry, that doesn't sound smart though.  I do occasionally give the output shaft a few rotations and try to shift the gears for S and G.
Thanks, Eric
If it was hypoid 90w I would drain it,the chemicals used in hypoiding does not play well with the brass in the synchro's I don't know if it is only while running or not but to be sure I would change it over to redline mtl and maybe give the input and output shafts a turn when I walked by to spread it around.
I believe it has some Valvoline 80/90 Gear Oil so probably not hypoid.   I have some Redline MTL handy so that could be an option.
25 minutes ago, tzei said:
I’d fill it FULL - as much oil as i could get in.
Interesting, I was considering just filling it up since it being stored in an unheated room it will see a lot of temperature swings. Being full up should limit the amount of moisture build up.
This. Stuff will rust above oil level. Needs to be rotated, moved etc. Full - just leave it. But seals needs to work.
Just not GL5.
Then fergeddaboutit.
I'd use a few quarts of whatever engine oil I had laying around that I wasn't going
to use for anything.
You REALLY can't hurt a transmission as long as you don't actively fill
it with water.
Oh- leave it in neutral.  Or better, for a 5- speed. reverse.
