Inherit my mess! :) M42 E30 + E36 + M47 crank + S52 trays...
Peter Lombardi
Hey there!
I've decided to go a different route with my engine swap, so I'm going to sell my gathered mess of partially disassembled engines and parts.
What's included, a partially disassembled E30 M42 (7mm valves but has the right oil pan), an E36 M42 (6mm valves, far more disassembled), most of the accessories for both, and both wiring harnesses. Also included for the price is an M47 diesel crank imported from Ireland that has the 88mm stroke and can be modified to fit the M42 to stroke it. Plus an M44 lower timing case and cover, this has the higher capacity oil pump (it's thicker), and a brace for the lower timing case guide from Germany. The E30 M42 was a EU motor so it came with a single mass flywheel as well. The E36 engine is mounted on a custom M42 stand at the moment also. Then there are the S52 lifter trays, these can be modified to fit the M42 as well, lightening up the valve train my taking it from 35mm lifter down to 33mm lifters. The E30 computer did get wet by the previous owner, so no promises on that, no ECU for the E36 M42. It also comes with a brand new BMW thermostat housing, haha, ooooooo. Both intakes are included as well.
All of the parts are spread around my tiny, tiny garage, so it would be hard to get it all together. I'm not looking to ship and I don't have a way to deliver at the moment, hence posting it locally.
When I took apart the motor I did a very bad job of labeling things, as I was planning on a complete rebuild, machining, etc, so I apologize for that. I would like to keep my bins, so please bring boxes or bins; I will try to find some as well as I organize it all after it sells.
I'm asking $1200, which is definitely a loss for me, but I want to move forward and get some space back in the garage.
Thanks!
