I'm still tearing things apart and the axle nuts on my '76 came off with no huge amount of drama.  Then the hubs came off relatively easily, I didn't need a puller on either side.  That seemed a little weird. One stub is threaded all the way to the end and the threads all look fine.  The other stub looks like this. Seems a little strange to me.  What is going on here, should these have threads all the way out to the end of the shaft or not?
The nut was on there very tight.  It's been like that a long time, I think, it appears to even have some black paint on the smooth surface where the threads used to be.  So what is the likely cause of the loss of half the threads?
Threads, schmedds, your problem is the worn splines ya gots there, Pappy!
(schoorryy, i been drinkin')
But seriously, I see evidence of wear on the splines- try cleaning everything
up really well, and see if you have a tight fit to the hub.
I'm afraid you're going to find slop, and equally ugh- inducing,
wear on the inside of the hub where the inner race clamps to it.
Which means you're over- clamping your bearings, and need to re- shim.
Or practically speaking, re- hubandstub it.
<hic>
