Removing Engine
PeterCS
Am in the process of trying to lift my engine out.  It is putting up a good fight. Have about 1/2-3/4 inch gap between the transmission and the block.
Do I have to remove/release the clutch lever?
Any other tips? Am about to use my pry bar.
thanks,
PeterCS
If everyone else ^^^ has been checked off the list,
wiggle.  Most common cause of binding is that the engine's at an angle
to the trans- or is putting force on at an angle.  And the tip of the pilot is at
odds with the clutch splines.
I do like Byron's theory on the lower plate.  The M54 version is a little 6mm bolt up
high on the passenger's side that holds the iso plate to the transmission.  Evil.
Also, one more reason to drop the subframe.
