M20 swap shift selector rod options
whatyear
I'm a few years into a project (1975 2002 with lots of rust repair now ready for a m20 swap) and am getting into the drivetrain + shifter/tunnel alignment.
I have an AKG short shifter that I'm going to mount ~2 inches behind the original tunnel hole (but still far enough in front of the emergency brake).
Now, I'm looking to figure out a shift selector rod to connect AKG shifter <> Getrag 260. I estimate I have about 4 inches between pins and wanted to see if anyone had opinions/thoughts on:
- Is ~4 inches too short to get the travel I'll need (i'm planning to build a mock plate + 2 screws to make sure it'll go through the gears but this is much shorter than stock)?
- Merits of a double shear selector rod (custom make myself or through Garagistic) vs attempting to shorten stock e30 rod vs using 2 heim joints and some adjustable center connector (see image). I'm leaning towards the DSSR route and have some concern a heim joint introduces too much "play".
- Bill
whatyearisthat.com
Bay Area
1975 2002 project-- going for sleeper & highway/cruise friendly
Stock m20, 3 core civic radiator, getrag 260
Chase bays brake delete
Shortened driveshaft- Driveline service San Leandro, CA
Catuned rear end w/ e30 3.73 diff
GC coilovers & IE 15 inch wilwood kit
TBD- wheels/tires, brake lines-chase bays e30 (i'm lazy), have good shape tobacco interior but might find tobacco recaros
shifterarmandhomemadeDSSR copy.tiff
Edited by whatyear
Building a m20 swapped '75 2002 sleeper in the Bay Area.
http://instagram.com/whatyearisthat
  • whatyear changed the title to M20 swap shift selector rod options
