Inside diameter of front strut tube?
2dingos
So going on the advice to use 1984 rabbit strut inserts for my 1974 02 with the IE coil over perches etc..... I had to get Sachs inserts as some of the others are not available right now.  They came in today and seem the OD of the insert won’t make it past the taper in the tube....
thoughts or measurements to share so I can return and re-order?
thanks in advance
arch
first bimmer, 1974 2002......undergoing ground up with S14
thanks in advance
arch
I'd start by Checking the inside of the tube where the welds are, might need to grind off any roughness. Then I would measure the strut cartridge diameter and compare to original and/or strut tube diameter. It looks like the inside diameter of the strut tube should be about 40mm. It's also a tight fit some people suggest using lubricant to make them slide in easier, might need to remove the parts tag.
