throttle shaft?
Rob Daino
Yes, anything's replaceable.
But as John notes, it's usually the throttle housing-
and that can be re- bushed by anyone who works on old carbs.
Autosport Seattle did mine 20 years ago- they do SU's, mainly,
but after a quick glance at the single Solex, said, 'oh, sure, no problems'
back when Seattle only sorta sucked.
Can be done.  You need someone who can fabricate a shaft.
heh
The pump crank off the end makes it a bit more tricky,
but that's just some file work.  I forget- is the throttle plate mounting surface
slotted or just cut away?  I traded away my last singles a few years
back for some Weber parts for the tractor!
Most of us, in your boat, fit a 32-36 for tunability and parts availability,
but there's not a LOT of powah to be had there.
