Pedal Box Rebuild - Hard Brake Pedal and Soft Clutch Pedal
Leucadian
So I just rebuilt my pedal box with IE kit, and a new master cylinder.  Got everything back together, bled the clutch line (5 speed) at both the slave cylinder, and at the master cylinder with a power bleeder at 15 psi.  Saw some bubbles coming out at the power bleeder when I slowly pumped the clutch pedal, after a couple pumps, the bubbles stopped.  Topped the reservoir off and still ended up with a very soft clutch pedal, with basically no resistance.  I checked from the reservoir to the slave, and didn't see any leaks anywhere, and the fluid reservoir isn't losing any fluid.  Potentially still have air trapped in the MC?  Bad slave now?  The transmission was swapped to a 5 speed 2 years ago, so the slave isn't that old, and no signs of leakage at the slave.  I've since bled the system 3 times with no luck.
On top of that, my brake pedal has only about 2" of travel.  I made sure the through bolt at the pedal box/booster assembly wasn't overly tightened, and lubed everything back up.  Turned the car over, and still, maybe 2-3" of travel.  The pedal assembly shouldn't be too tight because the clutch pedal has free travel
Also, is there any trick to pre-loading the spring for the throttle pedal on the outside of the pedal box?  I can get the spring over one rotation, but it doesn't allow me to fully seat the throttle arm.
So fully re-built pedal box with a non-functioning clutch, brake and throttle...
Edited by Leucadian
Engine bay OCD is a real problem
@02carbs
2" travel on a rebuilt pedal box with good brakes sounds about right to me, for the clutch is the bleeder on the slave cylinder pointed down? it should be for a 5 speed.
Edited by Son of Marty
George S Patton
