300 HP, How to Assemble Our Engines Engine Builders Chime In
Benjamin A.R.
10 hours ago, xr4tic said:
Not the latest, but the greatest M5 motor swap has already been done.
https://engineswapdepot.com/?p=20401
There we go, I just want a 4.4 twin turbo for all the shits and giggles as well as a little Gymkhana.  Now I know it will fit.  Just need to get @radwelds to fab a cage to handle the twist of the motor in a car that tiny.  Still going to build a M10 for the car I am working on currently.
  • Haha 1
59 minutes ago, gary32 said:
   I tried to buy one last year through my shop. Once I told them it was going in a BMW, they denied me, lol.  They only sell these motors to Honda based cars and they have to be in a race series with a heavily advertised/sponsored car. It wasn't as Grassroots as they claim. If I pushed hard, it might have worked but, it is cheaper to buy one out of a crashed Type R and build it to your HP needs. They are already flashing these motors and making over 400hp with stock rods.
72'  2002 turbo build - under construction...
Friend installed a brand new type r in his Lotus Elan a year or so ago not sure how or where it came from. I do not know anything about Hondas but he mentioned it was a complete dry sump motor and it was plug and play. That light weight car scoots and sounds good for a Honda.
V8?
GM performance connect and cruise e-rod LS3 6.2 liter aluminum block and heads compete from air filter to cat 430hp 422lb ft fuel injected with computer naturally aspirated CA smog legal with a T56 6 speed manual trans a complete brand new driveline for $15,600 and a 3 year warranty.LS3 E-ROD Manual Connect & Cruise Powertrain Sysem: GM Performance Motor.pdf
Edited by gary32
more details for evil
1 hour ago, gary32 said:
Friend installed a brand new type r in his Lotus Elan a year or so ago not sure where he got it. That car scoots.
V8?
 You can buy them, long and short block from any Honda dealer. It's just not a dry sump HTP motor.
I put a GM LT5 crate motor and T56 trans with ecu in my 68 Camaro. 755hp/715ftlbs tq. Pulley swap and it makes 950/950. with a GM warranty, lol
On 1/27/2021 at 9:24 PM, ray_ said:
Benjamin, aren't you supposed to Loctiteᵀᴹ that oil distribution pipe bolt?
Hmmm I've never seen that done, I would think the resistive kinda smashing action of the crush seals would make it not an issue. I could make it safety wired if that's a common thing but not sure.
https://e9coupe.com/forum/threads/m30-oil-distribution-tube.36055/
Ray
I skipped through the vid waiting for it to be driven.  I wish I could get those 30+ seconds of my life back.
So, to cheer everyone up. How about the S85 we just chucked into the M3? Fits like a glove!
Edited by evil02
I'm not sure whether you've got another 18 seconds to spare, but this looks like the same car (with the previous V-8 engine).
I'm trying to remember the member's name, but can't quite pull it out of my head.  I downloaded this video on Nov. 1st, 2017.  I checked and it did not come from the What Did You Do to Your 2002 Today! thread.
  • Haha 2
     DISCLAIMER
I now disagree with some of the timing advice I have given in the past.  I misinterpreted the distributor curves in the Blue Book.
I've switched from using ported-vacuum to manifold, with better results.
I apologize for spreading misinformation.
With an iron block 5.3 turbo weighing around 500 lbs not including transmission, that car is now a straight line only car. I call bs on the 2400lbs, engine weighs at least 200lbs more than stock and a roll cage and bigger transmission.
There is a reason GM never offered the t5 transmission with a 350 it's because people broke them with 305s, so why would you put one behind a 383?
Edited by 2002iii
