FOUND WTB - Ignition Module for M10 - e21 or early e30
Using realoem.com I found the module part # 12141705608 . You can find aftermarket replacement ones on ebay for $52. As for the connectors I dont even see them in any of the diagrams.
As an alternative you can use module part # 12141266702 and connector part #12521706059 which was used on many other cars. You can find both of these on ebay for under $15 each.
As for the wiring you can by automotive wiring and metal connectors from most auto parts stores.
Thanks for your help – I have decided to use the Siemens version, per your suggestion
