Rear Ride Height Question - 74 tii
diondiv
Hey Guys,
Happy new year! I am keen to get some feedback on the best was remedy a rear ride height issue.
I recently had some Eibach 1 inch lowering springs put on my 74 tii. Front is great, but the back has dropped a little too much (more than the 1 inch!) . I am experiencing a bit of rubbing in the wheel arch when driving through corners + the general camber of the rear is pointing inwards.
Can I lift the rear without replacing the new springs? Would an upper rear spring pad (1 or 3 dot) help with his issue? Any other suggestions/quick fixes? FYI back shocks are Koni's.
Cheers
Dion
Looks good Dion I would keep that height.
If you measure from the belt line front and rear on the centerline of your wheels the rear looks slightly higher.
Maybe give the inner fender lip a good roll and some inner fender reshaping.
Sorry senior moment I forgot you could confuse front and rear.
Edited by gary32
senile
7 hours ago, dlacey said:
Yes those pads top & bottom can increase ride height. No need to go urethane, the original rubber ones seem indestructible.
Just to make sure you know:  those upper spring pads come in three thicknesses, marked with 1, 2 or 3 dots--one dot being the thinnest (28mm) and the three dot being 38 mm.  Quite handy when it comes to leveling the car.  And the rubber ones will work just fine; they don't seem to wear out.
Just making sure, but you did remove the front strut top aluminum spacer correct? If yes, and you want to add a little height to the rear then I’d go with 3 dot rear pads. That should give you some clearance and still look fine.
edit: I see your from Australia, so I don’t think the front spacer will apply to you unless your 02 was a us spec version although I hear some from other countries also had these standard.
Edited by Jae
*Update - here's an image of springs on the rear of my car.
The code on the spring is 2001.001 - so it looks like the mechanic installed front springs on the rear of the car. Back springs should read 2001.002.
this should be an easy swap, but my mechanic cut 1/2 a coil top lower front... good times!
Another peanut gallery thought corollary.
Be cautious if your mechanic is fiddling with your injection system. And NEVER EVER let him "turn the screw"! EVER!
That said, if you take the dimensions of the cut spring, noting the compressed length if you can, then "we" can calculate the spring rate etc. as it will be used in the back. It "might" be not too far off an can be reasonably bumped up by the spacers.
You will need:
OD of spring
ID of spring
Wire thickness
Number of coils including partial
Free length
If anyone has the original specs, then we can compare.
Good to go.
