Djthom Posted January 3, 2021 Share Posted January 3, 2021 Hi All I apologize in advance for yet another wheel offset question but I wasn't able to find in archives. Will a 6x13" ET28 wheel fit a narrow body tii without rolling lips or otherwise rubbing? I often have passengers and gear for car events, and the PO installed lower springs so I want to err on the side of caution before moving forward Thanks Darren Quote Link to comment Share on other sites More sharing options...
Oldtimerfahrer Posted January 3, 2021 Share Posted January 3, 2021 Difficult to say definitively, but ET28 is pretty good but tire size is also a determining factor.... 205/60 is unlikely to fit. 185/70 on a 6 inch rim is quite tight. Andrew Quote Link to comment Share on other sites More sharing options...
visionaut Posted January 3, 2021 Share Posted January 3, 2021 (edited) Yes, if you fit a proper-sized tire on the 6” wheel. Given the offset on the proposed new wheel is only 1mm different that the OE 5” et29 rim , the new wheel will have its 1” greater width evenly split between the inside and outside, and there’s definitely room for 1/2” more to both the outside and inside clearance-wise. Edited January 3, 2021 by visionaut 1 Quote Link to comment Share on other sites More sharing options...
TobyB Posted January 3, 2021 Share Posted January 3, 2021 Yup. t Quote Link to comment Share on other sites More sharing options...
Djthom Posted January 3, 2021 Author Share Posted January 3, 2021 Thanks guys, appreciate the input on this Quote Link to comment Share on other sites More sharing options...
