sam1904 Posted January 2, 2021 Share Posted January 2, 2021 Hi all.... me again, While installing my DCOE’s with Halboyles linkage and a Korman manifold I think I have made a (potentially large) error... When I installed the brass pipe thread vacuum fitting off of #4 I think I over tightened it when I removed it once and reinstalled. Teflon tape may have sealed my fate? Now when I tighten I can essentially bottom it out with just ‘finger torque’.... Then when I fired the car up for the first time the rear two cylinders where pulling 1/2 as much air on my squirrel cage and it sounded like a very strong misfire. Combining these two facts I am concerned that I have a large vacuum leak around the brass fitting and hence on the rear carb as I have stretched the aluminum threads??? Sound feasible?? When I photograph the threads they still have form so I am hoping they are not stripped? I was thinking of adding some permeatex and reinstalling before pulling the whole thing off again? Any other suggestions? Thanks Sam Quote Link to comment Share on other sites More sharing options...
2002iii Posted January 2, 2021 Share Posted January 2, 2021 You could try using propane or map gas to check for a vacuum leak, while the engine is running use an unlit torch to put gas around the fitting and if the idle speed increases you have a vacuum leak. But it also could be a bad oneway valve sucking air from the brake booster, so you could pinch the hose off or cap the fitting to rule that out. If it is leaking vacuum you could re-thread it to a bigger size or use a helicoil. Quote Link to comment Share on other sites More sharing options...
man_mark_7 Posted January 2, 2021 Share Posted January 2, 2021 (edited) I have to say, I just installed the IE manifold w/ my DCOE 40s and was very puzzled by the way this fitting didn't want to fit very well. I was worried it was going to bottom out and not seal. My solution was a 2" long 1/4 NPT male-male extension into a T. I was able to thread it in until it seated quite firmly. I actually emailed IE who initially told me the fitting was 1/4 NPT, then emailed back saying it was actually 3/8 NPT. It is in fact 1/4 NPT (I think). I'm wondering if there were some issues w/ tapping @ IE. I also preferred the way the T allowed me to point the vacuum line at the brake booster versus straight back at the firewall. Good luck. Let us know how things turn out. Edited January 2, 2021 by man_mark_7 fixed typo 2 Quote Link to comment Share on other sites More sharing options...
sam1904 Posted January 2, 2021 Author Share Posted January 2, 2021 Thanks. This is actually a Korman manifold and I am pretty sure I have the right thread as it engages well. Unfortunately the more I messed with it and reinstalled it the deeper it went which is why I think I may have exerted too much force and the taper has essentially stretched the aluminum thread. I am assuming this is the case and not the fact that the male threads have become diminished? I also had the issue of meeting making the turn to the booster so I assembled a plastic elbow, I wonder if this is potentially not another vacuum leak sauce and I may see if I can source of brass variant. I do like your idea of just assembling a T and will try tomorrow, hopefully I also find something that has a slightly larger male taper and as such also helps solve the problem! Quote Link to comment Share on other sites More sharing options...
sam1904 Posted January 2, 2021 Author Share Posted January 2, 2021 Even though it is a new one-way valve I also need to check that again as I struggle as to if a minor leak around the thread could cause such a significant misfire and as such wonder if it is not sucking a lot of sir through the one-way valve? Quote Link to comment Share on other sites More sharing options...
Son of Marty Posted January 2, 2021 Share Posted January 2, 2021 At this point I'd just plug it up with a cork for now and see if you can bring the carbs into sync if they sync up then go back and repair the booster circuit as needed if they can't be synced then the problem is with the carbs or manifold. 1 1 Quote Link to comment Share on other sites More sharing options...
man_mark_7 Posted January 2, 2021 Share Posted January 2, 2021 45 minutes ago, sam1904 said: Thanks. This is actually a Korman manifold and I am pretty sure I have the right thread as it engages well. Unfortunately the more I messed with it and reinstalled it the deeper it went which is why I think I may have exerted too much force and the taper has essentially stretched the aluminum thread. I am assuming this is the case and not the fact that the male threads have become diminished? I also had the issue of meeting making the turn to the booster so I assembled a plastic elbow, I wonder if this is potentially not another vacuum leak sauce and I may see if I can source of brass variant. I do like your idea of just assembling a T and will try tomorrow, hopefully I also find something that has a slightly larger male taper and as such also helps solve the problem! Oh right - you said Korman in the first line of your post if I had paid attention. They look remarkably similar. On the IE manifold the ports don't connect with each other. I can't imagine that they would connect on the Korman either so i don't know why both of your rear cylinders would be pulling less. If the vacuum leak is from the brake booster line only the very rearmost cylinder should be showing less vacuum. Quote Link to comment Share on other sites More sharing options...
NickVyse Posted January 2, 2021 Share Posted January 2, 2021 Fit it permanently with some liquid metal, job done 1 Quote Link to comment Share on other sites More sharing options...
sam1904 Posted January 10, 2021 Author Share Posted January 10, 2021 On 1/2/2021 at 4:35 AM, NickVyse said: Fit it permanently with some liquid metal, job done Out of curiosity by liquid metal do you mean JB Weld? Thanks? Sam Quote Link to comment Share on other sites More sharing options...
NickVyse Posted January 10, 2021 Share Posted January 10, 2021 1 hour ago, sam1904 said: Out of curiosity by liquid metal do you mean JB Weld? Thanks? Sam yep Quote Link to comment Share on other sites More sharing options...
Hans Posted January 11, 2021 Share Posted January 11, 2021 12 hours ago, NickVyse said: yep I assume the "weld" in jbweld means you'll never get that sucker out if needed? I thought you said it was just #4 running lean. Did you sort out the thread size issue? I'd want to be sure that was my problem. I still think the carb to manifold looks odd. I'm pretty sure my gaskets are thinner. I'd do the propane test around each of those likely leak areas. Quote Link to comment Share on other sites More sharing options...
man_mark_7 Posted January 11, 2021 Share Posted January 11, 2021 5 hours ago, Hans said: ............ I thought you said it was just #4 running lean. ................... Yeah, this has me puzzled too. If it's not pulling vacuum on both rear cylinders then it's not the vacuum tap that's causing the issue. Quote Link to comment Share on other sites More sharing options...
sam1904 Posted January 11, 2021 Author Share Posted January 11, 2021 5 hours ago, Hans said: I assume the "weld" in jbweld means you'll never get that sucker out if needed? I thought you said it was just #4 running lean. Did you sort out the thread size issue? I'd want to be sure that was my problem. I still think the carb to manifold looks odd. I'm pretty sure my gaskets are thinner. I'd do the propane test around each of those likely leak areas. Thanks, Some thoughts. I did find an interference (with help!) where the cold start casting was hitting the manifold and this was preventing the rear carb seating fully on the gaskets, and especially #4. After removing the interference the flow rates through 3 and 4 came up but 4 is still around 10-15% lower. I have sprayed starter fluid at any possible leak sources and there is a (minor) change in tone, with that said all of those leak sources are also within 12” of the open stacks so the effect could just be the starter fluid getting sucked in that way… I am still concerned about the threaded connection from the ¼ pipe nipple into the rear of the manifold. It is absolutely a ¼” Pipe thread. The issue is that as with every tapered pipe thread, especially those where the female thread is a softer material (Aluminum vs. brass in this case) there is the opportunity to ‘stretch the thread’ through either repeated installations or in my case over tightening. In this case when first installed the nipple would seat with 1-2 wraps of Teflon with 2-3 threads still proud of the casting. At this point the same nipple (and another the same) will thread fully (e.g. 3-4 threads deeper) into the female thread even with far more Teflon tape. As such the average OD of the female taper is now larger allowing the tapered male thread to install more deeply. It also feels far looser and has more “angular” play during installation… You are correct that JB-Weld would be a permanent installation. However at this point it is a little bit of a moot point. If there is thread damage (which there is – even if not leaking) the manifold is at a point where if this fitting comes out again something different is going to have to be done… JB Weld would be the last option I feel… Before I go any further I have a 4 channel manometer arriving this week and am going to take a more detailed look at vacuum over each butterfly as my 40DCOE151 DOES have vacuum take offs… (Carbtune Pro Xmas present from my in laws! – always marry the daughter of a mechanic 😊 ) Will report back! Sam 1 Quote Link to comment Share on other sites More sharing options...
Hans Posted January 11, 2021 Share Posted January 11, 2021 i think the propane torch gives you better control of the jet. Quote Link to comment Share on other sites More sharing options...
2002iii Posted January 12, 2021 Share Posted January 12, 2021 I still say rethread it to 3/8" NPT, then get a 1/4" NPT male to 3/8" female adapter in brass. You can get NPT taps and fittings at your local hardware store. Quote Link to comment Share on other sites More sharing options...
