jon Posted December 28, 2020 Share Posted December 28, 2020 1976 BMW 2002 New 32/36 choke, new solenoid and new distributor installed summertime. Started and ran smoothly. Now once a week in winter, start takes a minute or so. Sounds like it had been flooded for a few seconds, but then runs fine. Winter starts used to be a little longer in that float had to refill. What should I look at to fix this hard start? Quote Link to comment Share on other sites More sharing options...
7502 Posted December 28, 2020 Share Posted December 28, 2020 Make sure your automatic choke is set up correctly. Might take a few iterations to get it where you want it, make small adjustments and note the difference. 1 Quote Link to comment Share on other sites More sharing options...
zinz Posted December 28, 2020 Share Posted December 28, 2020 40 minutes ago, jon said: Now once a week in winter, start takes a minute or so Is that on a cold start, or after it’s been warmed up and a restart? If cold, your choke probably needs adjusting as stated above. Pretty simple procedure. Ed 1 Quote Link to comment Share on other sites More sharing options...
zinz Posted December 28, 2020 Share Posted December 28, 2020 See here 1 Quote Link to comment Share on other sites More sharing options...
jon Posted December 28, 2020 Author Share Posted December 28, 2020 Cold start issue in winter has been after car sitting a week; restart after warm works fine. I adjusted the choke counterclockwise 1/8 inch and the engine fired, died and started after another 3-4 seconds. I don't mind if it takes seconds in winter to get gas into the carb, because the float never has worked well. The choke adjustment, I think, did what I need for wintertime. Thanks, Guys Quote Link to comment Share on other sites More sharing options...
Mike Self Posted December 28, 2020 Share Posted December 28, 2020 53 minutes ago, jon said: Cold start issue in winter has been after car sitting a week It's been my long experience with 2 bbl Webers (regardless of choke type) that they tend to drain after 4-5 days of sitting, and you have to pull gas all the way from the tank to refill the float chamber. Not sure why they do this, as the single barrel Solex on my '69 can sit for up to two weeks and start immediately. If my manual choke 2 bbl Weber has been sitting for less than two or so days, for a cold start I've learned to pull the choke out all the way, then turn the key to start without touching the gas. Then it starts every time. On an automatic choke carb, the equivalent would be to "set" the choke by pressing the accelerator pedal once; that will (should) cause the choke plates to close. You may want to make sure that's happening by pulling the top of the air cleaner on a cold engine, then working the accelerator linkage once, and observe the choke plates snapping shut. If they don't, something is sticking, or the choke just isn't functioning. mike 1 Quote Link to comment Share on other sites More sharing options...
