DrA76 Posted December 26, 2020 Share Posted December 26, 2020 Can I use 2002tii pistons on non too block? With E12 head? Quote Link to comment Share on other sites More sharing options...
Conserv Posted December 26, 2020 Share Posted December 26, 2020 Yes. There’s nothing special about a tii block, except for an oil drain hole for the Kugelfischer pump — which can be replicated on a “non-tii” block. But, yes, the pistons must be matched to the head, and an E12 head demands a piano-top piston, as you appear to have. Regards, Steve Quote Link to comment Share on other sites More sharing options...
DrA76 Posted December 26, 2020 Author Share Posted December 26, 2020 The new too piston is. a bit taller than the old one , about 0.5 mm is that ok? Quote Link to comment Share on other sites More sharing options...
AceAndrew Posted December 26, 2020 Share Posted December 26, 2020 Yes, the higher pop up represents a bump in compression. Very common for any 2002 rebuild. As mentioned, not specific to tii. Quote Link to comment Share on other sites More sharing options...
kbmb02 Posted December 26, 2020 Share Posted December 26, 2020 1 hour ago, Icecube76 said: Can I use 2002tii pistons on non too block? With E12 head? Why guess? Measure! (I admit - the more failed/crappy engine builds I take apart to fix (including wrong and/or poorly-specified pistons), the less patient I am with guesswork/speculation). -KB 1 Quote Link to comment Share on other sites More sharing options...
tech71 Posted December 26, 2020 Share Posted December 26, 2020 (edited) Odd looking piston, #1 compression ring groove is higher up than the original and more distance between it and #2 compression ring groove. Lower skirt is also different looking. Aftermarket no doubt. What are they? Just curious. Edited December 26, 2020 by tech71 Quote Link to comment Share on other sites More sharing options...
Son of Marty Posted December 26, 2020 Share Posted December 26, 2020 Yes measure everything at least twice and write down the results, if you don't have the mic's rent them or borrow them anything else is just a guess. Quote Link to comment Share on other sites More sharing options...
John76 Posted December 26, 2020 Share Posted December 26, 2020 22 minutes ago, AceAndrew said: the higher pop up represents a bump in compression. Any idea what the CR would be with the Tii piston and a E12 head? Manual lists the Tii as 9.5:1 (or 9.0:1 for USA) with the E12 head, and also 10.0:1 for earlier models. Are there any specs on the height of the piano top to measure? I have always wondered if my CA '76 has 8.1 or 8.3:1. Mine are piano tops...but appear to be "baby grands". Thanks, John Quote Link to comment Share on other sites More sharing options...
tech71 Posted December 26, 2020 Share Posted December 26, 2020 32 minutes ago, John76 said: Any idea what the CR would be with the Tii piston and a E12 head? 4 kind of pianos: 1.5-2mm dome but with 1mm recessed top piston to deck, 8:1cr early 74 49 states spec 1.5-2mm dome, 8,3:1cr, us spec, 72-74 4,5mm dome, 9:1cr (us Tii), often confused with real Tii euro pistons 6,8mm dome, 9.5:1 cr (euro Tii) flat tops on e12 head: 8,1:1, us spec 75 49 states From: Quote Link to comment Share on other sites More sharing options...
