Naseem Jarjoura Posted December 23, 2020 Share Posted December 23, 2020 (edited) YSo i just received the new bushings from Germany. The replacement bushings are rubber with the steel insert. The original ones as some of you may know have an outer steel sleeve that’s pressed into the trailing arm. This steel sleeve does not want to come out when I put it on the press. In fact when using the press to remove these bushings you run the risk of bending the trailing arm. Not good. I can get the bushings out with heat and press. Does anyone have any experience with the removal of steel sleeve? I’m going to try and saw a notch out and then possibly I’ll be able to knock it out? Edited December 23, 2020 by Naseem Jarjoura Quote Link to comment Share on other sites More sharing options...
Naseem Jarjoura Posted December 24, 2020 Author Share Posted December 24, 2020 Cut a notch out and then was able to press it out. Here is what it looks like. And a pic of the new bushing. Quote Link to comment Share on other sites More sharing options...
Naseem Jarjoura Posted December 24, 2020 Author Share Posted December 24, 2020 The last one I managed to press the entire thing out without using hacksaw on that outer steel sleeve. The new trailing arm bushings just pop right in with no effort. They get compacted once you torque them in to the subframe. Quote Link to comment Share on other sites More sharing options...
Slavs Posted December 31, 2020 Share Posted December 31, 2020 Those are the identical bushings used in the early 1600-2 and 2002 through mid-69. The rubber replacement bushings are too loose as they seem to be 1-2mm too small in diameter. That was the case with the batch shipped to me. When I tried installing them, they just fell through. I ended -up wrapping them with aluminum tape for a tight fit, but that's not going to hold up in the long run. Are you suggesting they expand in diameter when torqued in place ? Quote Link to comment Share on other sites More sharing options...
Naseem Jarjoura Posted January 1, 2021 Author Share Posted January 1, 2021 I thought the bushings would compress yes. However once I put them in i quickly departed from that idea. I don’t think it’s going to compress them enough, if at alI. was about to return them and order the ones that come with the steel sleeves but the fellow thats selling them closed shop until Jan 7th. I want to finish the project and reassemble every thing so I decided to epoxy the bushings in place. Those overpriced sad examples of a bushing are not going anywhere. Quote Link to comment Share on other sites More sharing options...
