IanIreland Posted December 21, 2020 Share Posted December 21, 2020 Finished up Auto to Manual gearbox conversion on 72 2002. Car wont start, or crank at all. There is power from the battery. Could this relate to a safety switch from the auto, where car needed to be in P or N to start it? Any solutions? Thanks, Ian Quote Link to comment Share on other sites More sharing options...
conkitchen Posted December 21, 2020 Share Posted December 21, 2020 (edited) There is a black/white (BL & WT) wire up under the steering column attached to the ignition. The needs to be bypassed and plugged into the back of the ignition tumbler. Now I will confess it's been a while since I did this last and had a wiring diagram out. Your issue is there. Look up the diagram and find the black wire. Then determine which spade terminal it needs to plug into. Good luck you can do it. Edited December 21, 2020 by conkitchen Quote Link to comment Share on other sites More sharing options...
tech71 Posted December 21, 2020 Share Posted December 21, 2020 The reverse light wiring is also connected to that switch, you will have to run it to the reverse switch on your new manual trans. Quote Link to comment Share on other sites More sharing options...
