Rear suspension
Go to solution Solved by '76mintgrün'02,
4 hours ago, mbarbary said:
It is listed in https://www.wallothnesch.com
as being used in 1502-1602
I see that, but your question was" are they the same?".
And the answer is no. Look closely at the pictures. Just trying to help you help yourself.
That said, somebody has to have these lying around in the parts bin.
Edited by Hans
More
1 minute ago, jimk said:
Where on the part do the cracks appear?  I am guessing in the bend area and they crack because the subframe load tends to buckle to strap.   It flexes back when the load is relaxed but in time it cracks in the flange area of the part.
Yep, that's where they crack.
I've observed two iterations of the straps - one lighter, one manufactured of thicker/stronger material. -KB
