Help - Beltline Trim 4 mm Bolt Access
To get to the back of there you need to remove the trim panel inside below the window...thats easier to do if you take the rear seat squab out first. The panel just pulls up, its clipped on a ledge just inside the window. I dont think its standard to have a screw-on fixing there..should all be plastic clips on that section.
It's unfortunate from an easy access point but the factory did put a stud plate in the leading edge of those quarter panel trim pieces.  There's a good reason, though.  If it were all plastic clips holding the trim, it wouldn't stay in place properly.  The stud plate can be tightened enough to keep the trim from moving.  Each beltline trim piece has at least one stud plate holding it in place.
