Price: $1500
Description:
Completely rebuilt 3.45 LSD. All new bearings, seals, fasteners. 2002 housing with e36 LSD unit, redrilled E21 output flanges, spacers and longer Allen bolts. LSD unit has 45# breakaway as well as the upgraded e36 LSD cover, better ring gear bolts, etc. This unit looks like a 2002 diff because it is one, the only difference being the e21 output shafts and spacers. It will be a bolt in to your 2002 while giving longer legs due to the lower gear ratio. Comes with 2002 rear cover, deduct $100 if you'd prefer e21 rear cover and swap your cover over. Shipping via Fedex Ground in a sturdy plywood box, overall weight will be 75# from zip code 30043 to your door.
