Gas Tank
diondion
More than likely the smell is coming from fuel vapors and not leaking fuel.
1. Replace the gasket around the fuel sender.
2. Check the fuel filler hose that connects from the exterior to the gas tank and the related gaskets. Likely something old and cracked that needs replacing. Also check to make sure any over flow hoses are routed out of the car.
3. Get rid of the fuel vapor plastic expansion tank in the trunk and plug any related hoses attached to it from both ends.
4. Did you replace your fuel lines from the trunk to the engine bay? If not, double check the run.
Good luck!
1987 Porsche 944 Turbo (sold)
1973 Mintgrun 2002 "Kermit" (sold)
1973 Inka 2002 "Ernie"
1986 VW Vanagon Syncro Weekender "Otto Van Gonzo"
Looks like James has covered everything regarding the possible cause of the smell.
I do, however, want the "second" James' recommendation of replacing the rubber o-ring seal around the fuel sender. Absolutely a must do.  Hope this helps.
Cheers!
Gary
