02 specific tools?
Fletcher
Noob question I’m sure, but noob I am..
I’m about to embark on a 1976 02 restoration project.  I’ve never worked on a BMW before.  I’ve done a limited amount of as-needed repairs to other cars (Japanese & American) and my tool kit at this point is all pretty generic craftsman mechanic tools.  My project will involve repair & replacement of body panels, interior furnishings and the installation of replacement engine/trans & driveshaft.
Are there BMW/02 specific tools I will need? And if so, any recommendations for inexpensive ways or places to source those?
thank you!
You'll need to pick up a metric set of sockets & wrenches for the 2002.  Craftsman, Husky or Kobalt will all do the job.  There are a few special things (super-thin or ground down wrench for driveshaft work) but those will get you started.  Good luck!
John in VA
Welcome to the FAQ!  You'll find lots of great info here, along with a couple grouchy people (myself included).  There are lots of great 2002 guys up in your area.
Here's a couple tools that come to mind, not exactly bmw-specific.
1) 2002 "blue binder" factory repair manual: It's available as a .pdf here on the FAQ.
2) Bearing Race Kit: From HF or similar.  It makes installing bearing races a breeze.
3) Hydraulic Press
4) Plastic trim/fastener removal tools (cheap off of amazon)
5) Flare Nut Wrenches
6) Pop-Rivet Gun and rivets
7) 02 Restoration Guide (by Mike Macartney)
8 Feeler gauge
Regardless of the specific car I'm working on, here's the short list of some random tools that I've found indispensable and probably would have HUGE regrets if I hadn't bought them long ago:
 - SIX-POINT (NOT 12-point) metric box end wrenches (mine are craftsman, but others available) for max grip when breaking 'old bolts' free. 12-point sockets/socket wrench for holding or once broken free are fine.
 - MAP torch.  Just get one and then thank me later.
 - For suspension work a good ball-joint separator (please no pickle forks) though funnily enough my favorite one is actually cheap from harbor freight:
https://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html
 - 1/2" drive breaker bar
 - Lots of 3/8" extensions
 - Ratcheting wrenches are nice
 - Ball end allen wrenches: https://www.amazon.com/Bondhus-38099-GoldGuard-Ballpoint-L-Wrench/dp/B000E7ZQIA/
 - Flare wrenches (as mentioned above) for brake lines.
If you find a job on a 2002 that you CAN'T get done with the above list, post back what it is and I'll probably remember what it takes, but I think that plus basic screwdrivers should cover just about 95% of the whole car right there.
  • If you're gonna mess with the rear axle...a 36mm 3/4" drive socket and a humongous cheater bar (275 ft/lbs to loosen or tighten).  And make sure your 1/2" drive breaker bar has a lifetime warranty...
  • A set of metric allen wrenches, and a specific allen socket (8mm IIRC) for the half shaft bolts at both the diff end and the stub axle end.
  • You'll also need a (help me out here, folks if I'm off by a mm or two) 22 or 23mm socket for the front suspension bolts
  • a pair of snap ring pliers for the clutch slave cylinder
  • A propane torch isn't a bad idea either for persuading recalcitrant bolts and nuts to surrender their death grip on each other.
  • a multimeter for tracking down electrical gremlins (and they will be present!)
Welcome to the '02 fraternity/sorority--and don't be shy about asking questions....lotsa expertise on the FAQ--nice folks too...
Fletcher,
Welcome to 2002FAQ - the best '02-specific tool you can have.  Sounds like you're a smart mechanic.  However, just in case you don't have them, make damn sure you have a damn good and exceedingly high quality...
  • fire extinguisher
  • first aid kit with an eye washer
  • eye protectors
  • jack
  • set of jack stands
  • charged cell phone (in your pocket at all times)
  • bold and prominently placed sign: "Disconnect the Negative Battery Terminal Before Working on This Car!"
  • person who knows you are in the garage
Now, you're set to look for '02-specific tools and have years of '02 fun.
Larry
There isn't much-  the oddballs might be, depending on your kit and your car:
7 mm wrench for brake bleeder.
8 mm wrench for brake bleeder.
11 mm flare nut wrench
6 mm allen socket
8 mm allen socket
10 mm allen socket
17 mm allen socket
30 mm socket
30 mm deep well thin wall socket
36 mm 3/4" drive socket (the Harbor Freight 3/4:"  drive set is useful for the price)
22 and 24 mm wrenches.  I have a 30mm as well, but I'm not sure it's critical.
Brass faced 3# hammer and brass drift
Acetylene torch if you're doing metalwork
(or other shrinking method for high- tensile steel)
Everything else is pretty bog- standard.
I'm sure I missed a few oddballs, but there just aren't that many.
Some of the things you DO are a bit different, but using Google to
search this site finds most of the answers, and you've already
found the other way to get help!
Have fun!
Edited by TobyB
MAP torch, Mike! Time to ditch that old propane!
Multimeter is a key one I forgot though, good call.  If you don't have one already, I REALLY like this one, as it's 25x scale puts automotive 12V systems smack dab in the middle for easy usage!
https://www.amazon.com/gp/product/B007IEFC8G
Not when you have a nice propane torch with a built-in lighter, and a half dozen propane bottles left behind by tenants whose movers wouldn't take 'em...free is good!  Besides, for the serious stuff, I have an acetylene torch...
Edited by mike
The most important tool of them all you already possess, THIS FORUM!
Get yourself a pair of Harbour Freight jack stands-NO don't just kidding but a lift if you can spare the scratch.
Edited by conkitchen
But what do I know
