Please help ID
Flamingo 5
Paul’s method, above, recognizes that the gears installed at the factory 50 years ago may not remain in the differential today. So I also would recommend his method. Nonetheless, a majority of differentials retain their factory gearing, and it’s nice to know what that was, as mentioned above and illustrated below, from the left front side panel of the housing:
Below is a 3.64 differential (11-tooth pinion, 40-tooth gear, designated by “11” and “40”). It’s also a limited slip unit (designated with an “S”). And it was manufactured May 1978 (“5” over “8”, stamped below the pinion and ring teeth numbers).
Edited by Conserv
Yes, it was originally, and probably remains, an open 3.64 differential, manufactured October 1978 (“10” over “8”). Double-check with Paul’s test. The rear cover is the later, finned-version of the ‘02 differential cover; I call the finned version the “square taillight rear cover”, but I don’t know for certain that the changeover coincided precisely with the first 1974 model ‘02’s.
I’m slightly hazy as to precisely when the e21 differentials switched from 4-bolt side covers to 6-bolt side covers — I believe it was with the 1979 model year (approximately September 1978). Your example suggests that approximately September 1978 could be the changeover. My May 1978 diff. has 4-bolt side covers (first and second photos below). Your October 1978 example has 6-bolt side covers (third photo below). None of this affects this diff’s suitability for an ‘02. It will bolt right into the short-nose ‘02 subframe.
Edited by Conserv
A pretty good indication as to when can be found in RealOEM.  In the E21 lookup, enter 1978 and go to the diagram for a 6 bolt cover.  It will respond, not that car.  Try the next year, same results.  It takes quite a few years to get a parts listing for a 6 bolt. I don't have the answer as to when the changeover in parts listing happens, but when I need to look up  parts, I've gotten accustomed to just going to the latest year.
3 hours ago, mgben said:
You definitely can go limited slip, you have the preferred 6 bolt side covers.
Contact Aceandrew as well as read up on it.
It all just takes money,
I’m not up to the job but, I’d love to know what to expect it should cost.
anyone been quoted a number ?
Oh, Paul, that'll never work...
What's odd is that it's stamped 3.64 but has 6 bolts.
The 320 trans, engine and diff all changed at about the same time, so
almost all of those have 3.91 gears in them.  It's unusual to run across
a 6- bolt case from a 4- speed car (3.64) OR it's from a 323.  Which is also
unusual in this country.
Oh no!
The 3.45 has been in my car since last year.  It was sent to me by a rebuilder in CA with the predrilled flanges and long bolts.  All I did was switch covers.  I put the newer cover on the 3.64 just to keep it closed and for storage.
Far as I can tell the 3.45 is doing its job.  Am I misunderstanding something?
73 Inka Tii #2762958
