AC burden on Engine
GDI
I have AC in my '74 2002tii that was put in just prior to my buying last year, and works pretty well considering.  It is a Behr unit and has an modern (Sanden?) compressor.  My problem is that it really seems to drag on the engine, when I come to a stop light the engine will sometimes die, and on accelerating from lower RPMs it will miss a lot  - I have to get the RPMs up to keep power.  The car generally runs very strong with the AC off, occasionally I have some missing/rough running when lugging the engine.
Any ideas of how I might diagnose/fix the problem?  I am tempted to bump the idle up, but I think that will just cover up the root cause.
Thanks
GDI,
I have the same AC in my 74 Tii.  I have the idle adjusted up to about 1000 RPM.  This seems to be about right and I haven't had a problem with stalling.  There shouldn't be much drag with the Sanden, at least not as much as with the original compressor that was installed in 74.
Glen
2 thoughts-
first is timing.  See if something unusual happens (a lot of retard, probably) when the engine slows
below 700 rpm.  That often happens with a worn distributor.
Second is an air leak.  Worn throttle shaft, especially, or loose macaroni, or broken gaskets.  That sort of thing.
A smoke test is actually pretty useful on a tii.
Or just about any car.....
Oregon smoke test:
  • Haha 3
1975 Malaga. It is rusty and  springs an occasional leak.  Just like me.
Thanks - I'm familiar with the "Oregon" smoke test - I utilized in my old '02 that I drive in college,  but I need to Google Toby's version.
I need to check the timing and inspect the distributor.  Good excuse to upgrade to a modern timing light and I may put in one of those fancy electronic ignitions with blue tooth and ApplePay...
