Bosch SR71 Starter Terminals
gsmith3
Take a close look at the solenoid terminals, they are numbered.  Then look a the wiring diagram, the terminals are numbered.  Connect the wires per the color codes on the diagram.  Same numbers are used universally on starters BMW used.
Terminal at 6:00 is trigger from ignition switch, you can jump a wire from battery to spin the starter.  Terminal at 12:00 is power to bypass ballast resistor only when starting.
HBChris
`73 3.0CS Chamonix, `69 2000 NK Atlantik
`70 2800 Polaris, `79 528i Chamonix
23 hours ago, gsmith3 said:
The starter is installed so I cannot read the terminal numbers.  That is why a sketch would help.
You don’t need terminal numbers, the bottom spade at 6:00 position is the trigger for the starter.
HBChris
Teach him to fish and he'll never to hungry. Throw him a fish and you have guest for dinner every day.
