majdomo
Sold Rebuilt 02 Heater Box
5 posts / 346 viewsLast Reply
(edited)
Price: $100
Description:
Rebuilt heater box - this was the one I used as an example before pulling the one in the car. Replaced all the grommets, heater flaps are resealed, heater core was pressure checked for leaks and came back great. Motor works a but makes a bad squealing noise, may need to be replaced or just lubricated. Replaced the wires and did all the heavy lifting with cleaning, replacement O-rings and so on. One minor crack repaired with JBWeld, this side faces the firewall however and you don’t see it installed. (Mine did the same thing.) As you can see the valve bracket is busted, but you can purchase an aftermarket bracket and fix this right up quick. All it needs is a little bit of finishing before installation.
$100 plus ship obo. Thanks!
Edited by majdomo
More photos
