1600/ Early 2002 parts
02tradition
Price: $1
Description:
Please take 30 seconds to read the ad. Parting out another ‘68 1600 sadly (yes it’s too far gone). Will add more to the list as I pull it. More pics available by request I can only post 40 pics but I do have pics of everything. Discounts available if you buy more than one thing. Small items can be shipped at buyers expense. I will update ad AS SOON AS something is sold. Easiest form of contact is PM here on FAQ or Text 7143513394 - Andrew
Oil Pump $100
turn signal stalk $40
d/s seat w/ rails $100
clear glass set (no front windshield) $300
Gas cap $10
frame rails $80/each
rear shock towers $80/each
rocker panels $75/each
a pillars w/ hinges $40/each
early shift cup $20
rear seat $40
Rear Vent window hinges $80
front vent window mechanisms $40/each
window regulators $75/each
d/s door catch $40
b pillar trim $15/each
rear vent window trim $15/each
between tail light trim $40 (couple dings)
Passenger door $60
roof section $200
complete tail lights $150
steering box w/ arm $180
Tension Struts $75/pair
Steering column w/ key $100
front control arm $75/each
71mm crank $60
front crank hub $50
front wheel hubs $75/pair
connecting rod set $75
Black Ops (w/ black plates) $1000
SOLD
rear bumper
transmission
dash
mechanical clutch
Complete rear subframe w/ diff, etc.
complete cyl head w/ manifold & carb
air cleaner
wiper motor
Oil pan
rear view mirror
bilsteins
front bumper
strut housings
brake servo
rear emblems
hazard switch
pedal box
headlight buckets
drivers door
brake calipers
spare tire well
Trunk lid w/trim
int door handles
ext door handles
pass seat
tail panel
swan mirror
trunk lock w/ key
wheels w/ hubs
Seatbelts
complete gas tank
DIDN’T COME WITH
Hood
fenders
nose panel
grilles
windshield
Edited by 02tradition
Would you mind sharing the VIN, (a.) for our Register, and (b.) for our database of when the outside rearview mirror -- and other '67-style features -- were phased out? It appears that the rearview mirror mounted at the leading edge of the door lasted at least until October 1967, a couple months into the 1968 model year.
I'm guessing it's a 156xxxx car, and perhaps even a 1560xxx car.
GLWS,
Thanks and regards,
Edited by Conserv
3 minutes ago, 02Anders said:
What he just said.   ^^^^^^^^^
Thank you!
Or show the other side of the rear light reflector housings. Might have the date inked on them.
@02tradition, it's not my business to tell you what to do with this car but it's tearing me apart to see such a restorable early 1600/2002 car. It is so solid and has so much potential to be restored again. I keep going back and pouring over the photos one by one.
I love the car and hope someone can save it.
Again, do what you have to do but this a very restorable solid looking car! It's heartbreaking to see it get parted.
11 hours ago, 03to02 said:
Pm sent on hub caps and rings.
I just want to note that the “dog-dish” hubcap and separate trim ring shown (above and first photo below) represent a now-rare combination that we see in Road & Track’s May 1968 road test of the very first U.S.-spec 2002, VIN 1660001 (second photo below).
The road test 2002 was manufactured November 29, 1967.
The trim rings were stamped out of the thinnest of aluminum(?), rendering them shockingly fragile, exactly as the photo suggests. ?
Edited by Conserv
As in the August 13, 1969 light below.
Thanks and regards,
You havent seen the front of the car...
57 minutes ago, otisdog said:
Stitched door cards?
Observing, not requesting....
I suspect the seats were re-done as part of the same project: smooth vinyl pleats with contrasting stitching. ?
Edited by Conserv
