Rear Wheel Bearing Sleeve Wear and Measurements
2002#3
I have read service manual (SM) info posted FAQ info on the subject of using shims to space rear wheel bearings; however, I want to make sure I understand.
Status:
-- Replacing stub axle, bearing, and seals, one side at a time.
-- Both ends of the wheel bearing sleeve have flat-bottom 0.2-mm-deep grooves.
-- Sleeve measurements:  unworn rim-to-unworn rim, 64 mm; groove-to-groove, 63.6 mm.  Bearing stop-to-bearing stop, 60.7 mm.
-- no wear on hub or stub axle contact points
-- The only shim in place is the standard 3 mm shim.
-- Following SM guide for calculations.
Q:  How does one take into account sleeve wear when calculating appropriate shim thickness - simply follow SM and use whatever shim results in 0.1 mm of play?
Q:  Use the 64 mm or the 63.6 mm for the sleeve measurement?
Q:  Should calculations indicate an increase or decrease in shim thickness with sleeve wear?  My calculations indicate decreasing shim thickness to 2.8 mm (63.6 - 60.7 - 0.1 = 2.8).
Q:  0.2 mm wear on each end is OK, so reassemble with new parts, carry on with the 3 mm shim, and have a G & T?
Thanks,
Larry
Hi Larry,
Fairly sure your calculations of 2.8mm are correct. As you recall I put 90K on Vern before he was restored. Afterward I was replacing the passenger side rear every 7K miles. VSR measured 6 ways to Sunday, measuring a dozen times and found my bearings had zero play and were way too tight. Think the overall shims on the passenger side are 2.5 mm. I recall they had to mill one shim in half to get 2.5.
Drove all 2019 with zero noise or bearing issues. So they nailed it!.
Andrew Wilson
Quote
A: Both ends of the wheel bearing sleeve have flat-bottom 0.2-mm-deep grooves.
II.Sleeve measurements:  unworn rim-to-unworn rim, 64 mm; groove-to-groove, 63.6 mm.  Bearing stop-to-bearing stop, 60.7 mm.
3: no wear on hub or stub axle contact points
A: you need new sleeve(s).  They aren't supposed to be worn at all.
   In fact, they should present a flat surface to the hub and inner bearing race, as their unit loading is
     already nearly too high for what they are, statically assembled.  Put some cornering load
     in there, and it's even worse.
II. see A, above.
3- Well, huh.  Are you dead sure?  Then someone's been in there, and replaced
all the expensive parts, and forgot the easy one.  Get new sleeves, and measure again.
And put up pix of your mating surfaces.
iiii. I've cut, ground, re- surfaced and re- shimmed stubs in 3 or 4 ways, and as long as the
    bearings are not preloaded hard against each other, it all works pretty well.
    The only thing that really matters is that the space between the inner race and the outer race
    is the same.  Everything else can move (a little, you do want the brake shoes to hit the drum)
Loose Balls Last a Long Time.
Edited by TobyB
I find the challenging part about the job you’re doing is finding a method/tool to accurately measure the distance between the ‘bearing stops’ inside the trailing arm. I finally made an almost-bearing-size device I can slide into the trailing arm, which makes it easier to plunge a caliper tip and get a reading.
And when it doesn’t all work, shim-zies. -KB
Is the table on that surface grinder magnetic?
