Routing of wire from starter to coil - ‘74 model.
kbmb02
I’m working to get the wiring back to original funcationality on a ‘74 2002tii.
This car has the resistor wire from fuse block to the coil + (no separate relay, or physical resistor). The schematic shows a red/black wire which supplies ‘full’ battery 12V to the coil during the start sequence, with the wire originating at the starter and ending at the coil +. For those who have late model 2002’s with similar configuration (I don’t believe it needs to be a Tii, but maybe), where does the red/black wire fit in the wiring loom? Is it a separate, single wire? What’s the route to the coil (in the loom, via connector near the bulkhead, etc.)
Thanks in advance. -KB
3 minutes ago, John76 said:
The red/black is in the larger of the two blue harnesses that run across the top of the firewall.
Thanks, @John76
There is no blue harness on this car (so much for Pebble Beach...) Did Tii's have a blue harness?
I'll clarify: My question is more about how/where the red/black wire routes from the starter and into the harness. Does it route down the side of block in the harness which then runs up the inner LH fender? Does it route from the starter 'rearward' to the firewall? Does it route from the starter over to the corner of the firewall near the fuse box? -KB
2 hours ago, kbmb02 said:
Thanks, @John76
I believe, John, that the “blue harness” may have just appeared with the 1975 model, with the advent of the thermal reactor exhaust manifold, which multiplied the emissions controls. At that time, 1975, the windshield washer reservoir moved to a position over the brake booster, and the coil moved to the reservoir’s old spot. I would guess that a ‘74 tii’s wiring harness for starter and coil might be similar to a ‘73 tii’s set-up... Maybe?
I can’t answer Ken’s question, but I’m thinking that @OriginalOwner, @GlenKarr, and @JohnD, all original owners of ‘74 tii’s, can probably answer the question!
Best regards,
Edited by Conserv
