Engine id help needed- 1800 ti hot rod?
16vguy
  • 1 month later...
  • 1 month later...
On 4/8/2020 at 10:51 PM, MOJOJOY said:
Building on the above from Daniel, VIN 1516265 is certainly an early car, probably February 1967 or thereabouts. At no cost, BMW Group Archives can provide the car’s exact manufacturing date. Just email them the VIN and request their data on the car. Their email address is:
info.grouparchiv@bmwgroup.com
When there is no VIN (engine number) — not ultimately the case here, of course — M10’s have casting dates, which can narrow the possibilities from an identification perspective. I would generally expect a 1600-2 manufactured in February 1967 to have an engine block cast in February 1967 or within approximately three months prior to the car’s manufacturing date.
Although heads have often been swapped over the last 50 years, heads, likewise, have casting dates — year and month — on their left (intake) sides. The exact location of head type and casting date vary. Below is the original head from my ‘76, cast April 1976 (4 nubs surrounding “76”).
Edited by Conserv
The Weber 45DCOE 15/16s were indeed initially used on the 1800 TI/SA, but were also used by Alpina in many of their applications.
The headers appear to be Alpina, and we know the carbs were used by them, the next thing to look at are the intake manifolds. Alpina used factory TI manifolds AND their own as far as I know. If factory BMW TI manifolds for a small port 118 head, they’ll have 118 cast in them between the ports either top or bottom. Same goes for intakes for large port 121 heads and TISA1 heads as well. The TISA1 heads had large intake ports like a 121 and still the small exhaust ports of the 118.
Have you found the head casting on the intake side between cyls 3-4 yet? There’s a circular date cast there as well. On TISA1 heads the TISA1 is cast between cyls 2-3.
Cheers and Hope This Helps,
Tom
Tom Jones
BMW mechanic for over 25 years, BMWCCA since 1984
66 BMW16oo stored, 67 1600-2 lifelong project, 2 more 67-8 1600s, 86 528e 5sp 585k, 91 318i
