Cooper
Catastrophic engine failure
51 posts / 2642 viewsLast Reply
24 minutes ago, Cooper said:
Since pulling just the pan seems to be a unascertainable amount of work, and I already have an engine in pieces sitting on a shelf and another engine on the stand, it’ll be a little bit until I get to pulling this engine and taking it apart, sadly. But when I do, I’ll be sure to share the carnage
it ain't as hard as some are making it out to be...
at least drain the oil into a pan and shine light in oil to see the sparkling metal shavings....
Fine, I’ll give into pier pressure...
this is all the none-oil that came out. No pieces of bearings or anything, but a bit more then you want to find in your oil I think.
i also took the valve cover off to see if the cam sprocket popped of or something. All was fine under there, so It seems like we can rule out a timing chain issue.
By the way, if anyone was looking for engine vin# 2571569, uhh, sorry. It’s kinda broken. I’ll give you a bangin deal on it though!
  • Sad 1
(edited)
Shiny granular bits probably ferrous metal. Shredded oil pump gears most likely.
Oil starvation would do that, fast.
Stick a magnet to it.
Edited by tech71
