Weber 40’s side draft filtration options
Dionk
OOfff. those are going to be hyper-restrictive, and as Stevenola alludes, disrupt the airflow into the trumpet.
Carbs/throttle bodies, etc, all want a large volume of smooth, still air to pull from if possible with as little restriction as possible. So the best option is a large-volume airbox, with a high-surface-area filter that's as far away from the face of the trumpets as possible.
Tons of options out there. Pancake filters are low-profile, but offer little air-volume, typically don't allow for trumpets or only very short ones, and a small surface area to the filter. There's tons of Foam options, between socks, per-carb options, or large volume filters that encase multiple carbs in one volume.
All the single-throat stainless mesh stuff is for show-only IMO, and will rob you of many, many hamsters- What you show seems like an even worse option IMO.
Edited by 2002Scoob
If you're into originality, you can also look for an original Ti style airbox that came on a variety of cars/models, or the Alpina version too.
image.jpeg.5b31bab3df20df6ace8ed7eb285b4898.jpegImage result for ti airbox bmw 2002
Those are actually proven to make decent power and be a great option vs. most else that's out there.
Edited by 2002Scoob
Bring a Welder
14 minutes ago, Dionk said:
What size flange did you buy? Would you buy the same size again?
I, uh, cannot recall where I placed the order to find the receipt.  Searching my emails and memory, no luck.  May have simply walked into Summit Racing and bought them in person.  I'll see if I can find a part number on them tonight.
Yeah, I'm happy with them for the most part.  Only issue is the stock  base model brake booster in the way.  They'll fit around it, just one pops up a little and looks goofy.  I was hoping the bend would be enough to get around it, but no.  Maybe combined with bent stacks it would look better, but I haven't cared enough to pay for those, and just using the straight ones.
Edited by KFunk
Bring a Welder
+1 on the UNI filter
These are what I've used for many years with great success.  HUGE filter area and the angled bases help clear the standard brake booster, too.
https://www.denniskirk.com/uni/two-stage-pod-filter-w-angled-flange-2-1-2-in-i-d-x-6-in-l.p305050.prd/305050.sku
Here they are on my engine
Edited by zinz
  • Like 3
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
There we go, managed to find the order confirmation in my email, Dennis Kirk is where I bought them:
Two-Stage Pod Filter w/Angled Flange - 2 1/4 in. I.D. x 4 in. L - UP-4229AST
Part #: 305044
Bring a Welder
I run the stock ti airbox with 45dcoes, I don't pull it off that often, maybe every two years. Is not too fiddly for my taste. Original boots fit over angled trumpets, I have some rubber sleeves on the outsides of the trumpets to ensure no air leaks. Works ok, less intake noise bet that's ok. I want to put it on the dyno to see what the loss is.
Andrew
1971 2002ti, 1985 E30 320i, 1960 Land Rover 109 Ser 2, 1963 Land Rover 88 Ser 2a, 1980 Land Rover Ser 3 Lightweight
