tii engine rebuild and 5 speed swap
mvliotta
Hi all.
While the block and pistons are at the machinist, I’ve been ordering parts and cleaning stuff up. Will post pics soon.
Having a hard time finding an BMW oil pump chain. Seems like my options are
1. Purchase wider-than-spec Iwis or Febi chain
2. I think I can find a BMW split chain with master link
3. Use my old chain and shim it up.. a lot
Anyone know how I can get my hands on a BMW chain these days?
Also, what do you guys think of the wear on my cam sprocket?
New one of these is pretty pricey, unfortunately
Edited by mvliotta
'72 2002tii 'Liesl'
Starting to quote myself..out of control
New BMW chains, either split or endless, are nowhere to be found. So am stuck with a new chain of the wrong size (with some use by folks here) or reuse of my old chain with new pump (and shimmed).
What would the ‘02 wizards do? ?
'72 2002tii 'Liesl'
9 hours ago, mvliotta said:
Hi all.
I would not suggest #1.
For what it’s worth, I will sometimes use a ‘pre-stretched’ chain on the race engines, shimming as needed.
In your case, the cost of shims might grow... -KB
On 1/22/2020 at 2:07 PM, mvliotta said:
What swayed me was info from a couple of FAQ members that have installed 10:1 pistons with 121 heads and a discussion with a head mechanic at a shop that has installed dozens of these over the years. In summary, satisfied drivers, with no reported detonation issues that I could find when using 93 gas, which is plentiful in the eastern US.
I'm limited to 91 Octane, my machine shop cut down my 10/1 pistons to 9.5/1 to avoid fueling issues
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
chains do not stretch, they wear  a good  friend of mine just bought the correct chain from bmw na, a low milage chain will work, the shims are nla, thats why I save them,  I have never seen a broken oil pump chain in a m10, lots of bad chains and gears in later splined pumps if you can't find it I might have one  Bruce
the only way to ck a sprocket is compare it to a new or low milage sprocket, I have lightened and advanced/retard stock oem gears, not that chinese pos that ireland sells, tried one was not the correct size could not get it on to the cam sent it back.    yours has wear,  which   means the crank gear needs replacement, it wears twice the rate, if you put a new chain on these, ck where the tensioner rail ends up with  light pressure in the front cover/tenioner cavity, too much wear it will be close to bottom out to the cover
4 hours ago, m-tuner said:
compare the ends of the teeth they should have a flat section at the point, same with the crank gear,
Thanks Bruce. Getting new crank and camshaft sprockets.
Hopefully will be putting everything together soon.
'72 2002tii 'Liesl'
While I’m waiting for the block work and the last parts to arrive (hopefully getting a correct oil pump chain!) been doin a lot of cleaning.
Between Paul’s blast cabinet, my scrubbing and the local Cad plater, parts are cleaning up nicely!
Getting a kick out of finding all the original date stamps..
on the timing chain covers:
intake plenum and stubs:
distributor housing:
and water divider:
Cant wait to put it all together.
Edited by mvliotta
  • Like 4
'72 2002tii 'Liesl'
intake plenums and stubs:
and water divider:
Very very nice, Vince!
Did you say “cad plater”? I’ve been looking for a NY or NJ plater since we returned from Atlanta. Name and town of yours? Bona fide yellow cadmium or yellow zinc? Either would be great; actual cadmium would be even better!
Best regards,
Yep, real deal. Did mine in yellow cadmium. Was surprised to see a place like this so close to me. They’ve been in Montclair NJ for 50 years.
http://www.alcaro.com/index.html
If you take a ride here, let me know. Would be great to meet up.
Vince
'72 2002tii 'Liesl'
Vince
Wow, Vince!
I’ll PM you when I pull a load together for plating (I believe I have half a load ready to go.).
Thanks and best regards,
Edited by Conserv
Vince
Well, it's New Jersey, so, anything goes.
Vince. Did you run into Jimmy Hoffa in the back field dump?
  • Haha 1
  • Sad 1
1974 2002 Tii-SOLD
1978 911SC Coupe
1988 Landcruiser
2020 M2 CS
