Scottjeffrey
Some guidance on hours to do rear....
21 posts / 974 viewsLast Reply
Hi, I am looking for an informed, ballpark estimate for hours of labor to;
-drop the rear subframe
-change trailing arm bushings
-sub mount bushings
-Rear bearings
-new cv boots
-reinstall subframe
Thanks very much. It would be of enormous help to me.
Best Regards,
Scott
FYI I only drop the frame 1.75” to do what you’re taking about, makes reassembley Very quick
are you asking about shop rate?  DIY rate?  there are some special tools needed to do several of those jobs.  is the rusty/dirty? (takes longer)  have these parts been apart in the last 40 years?  (if not, takes longer)  there are also "while you are in there" considerations.  time to just do the minimal work list or will improvements/cleaning be done to make the car better while in there?
that is a solid weekend's worth of work.  a day if everything is clean and loose.  a week if everything is 40 years old and you want it to look nice.
  • Like 3
What he said... and since I see "rear bearings" and "new cv boots" (which imply disassemble/regrease of all cv) then I'd assume you want the larger of the options. Shop rates for "while you're in there" can add up. If I had only that job to do and gave all my time to it it was probably a weekend of work with hand tools. Degreasing/cleaning/painting/drying took the most time.
Sent from my SM-J327VPP using Tapatalk
At least the same as my front subframe estimate, and don't forget the cleaning and servicing the differential, it's carrier, rear carrier bushings, etc. Brake lines? Rebuilding brakes? How are the E-brake lines? Those stupid things took forever because they were jammed in the tubes.
Again, it depends on your level of detail and involvement. I sanded, treated and painted my subframe. Plus, I found a few rust holes in it that needed cutting and welding. It would be expensive to have someone else do the whole job.
Actually, not sure why you're asking Scott. You did the same for the front and ended up doing it all yourself. This is the same. Just drop it and go. You can't do it in a weekend, at least I can't. Took me weeks of intermittent attention, but I was new at it.
GL
Nick
51 minutes ago, Buckeye said:
Zambo (member) recently did complete rear suspension and drive.
BTW, are you finished with front suspension? Do you mind share a few pics?
https://www.bmw2002faq.com/forums/topic/201295-what-did-you-do-to-your-2002-today/?&page=322#comments
Hi Buckeye. Everything is waiting to go back together up front. I got held up by a parts supplier on the rubber boots that go inside the strut assembly. Ended up going to my local BMW dealer who ordered them from Germany. 5-10 days. There wasn't single one in the states. Thinking I might as well get started on the rear. It looks like a pain in the ass because of tools I lack such as a air gun and flange puller. I shall succeed! Thanks for the info on Zambo.
Best Regards,
Scott
GL
Nick
I am considering taking it to a local older BMW guy because I was just offered a job which would require the car being on the road. I currently work across the street from my house. No traffic, lol. I hope all is well with you, Nick and thanks for the help as always.
Scott
I had my guy here in Orlando drop the sub frame and replace all bushings, added toe-in and camber adjustment refresh and re seal diff and paint the whole thing. I think it was around $1000.
Thank You Mike!
Sounds cheap. Nice!
that was a screamin' deal.
That is a crazy deal.  In Vancouver that is a $3K bill all day long.
-sub mount bushings
-Rear bearings
-new cv boots
-reinstall subframe
Best Regards,
Scott
In the while you are at it category, replace the brake flex hoses if you haven't already.  I did urethane bushings for the trailing arms, but did a stock subframe mount with the I.E poly insert.   It has a nice firm ride that I like,  and at least in my case I don't find it too noisy.
From someone who just dropped the subframe and replaced all bushings and cleaned and painted, it took me roughly 2 weekends.  Roughly 32 hours of work.  I did not replace bearings or cv axles.  You will also add hours on top of 32 if you run into issues like seized bolts or cracked subframe mounts that need welding.
