PeterCS
Wiper refills
9 posts / 396 viewsLast Reply
I need to replace the rubber on my wipers.
all the discussion on the web is about the right length.
Modern inserts are a lot thicker and don’t fit my blades.
am I mistaken. I don’t want to order new replacement inserts that are too thick.
As always, thanks for the advice.
PeterCS
I'm pretty sure I used the Trico refills, as well, though I had to actually take the refill apart and transplant the rubber into my existing blade frame, as the Trico frame didn't have the right indents. This is for a '67 1600-2, though. I can check tomorrow if you haven't found any.
Yes, I agree with Dan  (Coloinca). If  just replacing the rubber blade is all you seek, the Napa classic fit (although I think they are made by Trico) what I believe are my original Bosch arms on my ‘74. $1.65 on EBay.   (As recommended elsewhere on the FAQ.)
(edited)
Warning!  Do NOT drive your 2002 in the rain.
Problem solved.
Edited by lilmo
FYI, pre 1970 1600s and 2002s came with 13 inch wiper arms/blades; later ones were 15."  Silver arms and blades on roundies, black on squarelights.
