Luke's02
Transmission support mount with no place to go?
16 posts / 660 viewsLast Reply
So as I was putting together my engine I noticed that the place where this transmission support bracket goes has no holes drilled in the block. The engine block i'm using is a 1974 as opposed to my original 1973 car which I pulled the bracket off from. I could not find any information anywhere regarding this problem so I thought id come to the forum. Seems weird the engine block I have would not have those holes.
IMG_4006.thumb.jpeg.bcaad227e73d19c53a00398cba72bbe8.jpegIMG_4007.thumb.jpeg.9e1eaebca4fc0b901d127501dff8f0b5.jpegIMG_4004.thumb.jpeg.48f781e38e59279a7cb62b68555f74a1.jpeg
The engine blocks vin has been ground off so I can not say whether its a tii or a base engine block. This engine I got is actually somewhat a combination of parts including high compression pistons and a 1984 head from a later model m10. The build of my engine from what i read only works this way using an early (2002) block with a late model head (e21).
Is the block out of a later car (e21)? they deleted those after the 02 production also not sure if automatics were drilled for them ether although I'd think they would be. Anyway look for the casting date on the block to narrow it down a bit.
Edited by Son of Marty
There is a chance my block is actually from an e21. It was my understanding that it was from a 2002 but if thats the case you may be correct.
What is that bracket used on?  My 76 didn't have it.
Should be easy enough to drill and tap the holes for it though.
According to the Haynes manual it is a transmission support bracket but I have not been able to find much information about it and whether or not it is very necessary. It sounds like it was probably on early blocks and then they removed them maybe in 1974 and up perhaps? Anyways my block casting looks like this, not sure the date on it.
Never had one of those on my ‘74, which still has the original block.  Transmission hasnt fallen out in past 14 years of ownership.  Throw it in neighbor’s pool?
  • Haha 1
The lower most bolt on the transmission bell housing to engine runs thru this bracket.
My 71 block/trans had it and when I built an engine from a 76, I used the bracket.  I also use it now on the S14/245 trans bolting.  The S14 block has the 2 threaded holes in the block for attaching the bracket.
6 hours ago, Luke's02 said:
....Anyways my block casting looks like this, not sure the date on it.
The casting date is within the oval frame below the number 1 and number 2 freeze plugs (on the right side of the engine) — it’s just not particularly clear in the photo above.
Below is the casting date on my ‘76’s block: March 26, 1976 (“26C76”).
8B5032EF-9D9A-4AF7-B412-F23C70884939.thumb.jpeg.86dce5f1c0decb0a39c2dda4ab879c68.jpeg&key=23adf70922748a353f7805bda30508321c321e311606a765b8d8805d27fe3baa
Steve,
Blowing up the OP’s original pic on my iPhone, it looks like either “1J76” or “11J76” - either way, making it 1st Oct ‘76 or 11th Oct ‘76 I surmise ...
Richard
I went back and looked at the casting date on my block and it does in fact say 1J76.
Edited by Luke's02
