rcf925
Timing Chain Tensioner ?
22 posts / 714 viewsLast Reply
(edited)
RELIEF, anybody ever hear rocker hitting valve cover? if I tighten valve cover bolts it hits, If I set cover on loose it's quiet, What the hell, Thought I was going to tear whole motor down again. Anybody see any problems with just using 2 valve cover gaskets? Thanks for everybody's help
Edited by rcf925
(edited)
Rockers touching the valve cover with a single gasket is not normal, adding a gasket to fix this is as good as just turning up the radio. You still have a problem. Is there a chance that the valve cover has been cut down?
Edited by Furry Camel
(edited)
It was 1 rocker touching just enough to make a knock, Didnt really leave a mark, I'm running .292 cam with .393 lift so maybe it was just enough to hit. I have another valve cover around, I'll see if it's the same as the one I'm using. I just drove car for about 20 miles, No issues
Edited by rcf925
What rocker arms are you running? I’ve had them hit the oil spray bar but that is with a 316 or 336 cam!  If you are hitting with the valve end of the rocker that almost has to be a cam with a ton of metal removed from the base circle of the cam and the oversized adjustment eccentrics adjusted almost all the way down. Unless someone has surfaced the TOP of the head and/or cam cover.
I'm with Byron (Preyupy) there's a fair amount of clearance to the valve cover/rocker, hard to figure whats going on there maybe a valve seat recessed to far into the head or valve lash caps and over sized eccentrics?
Cam is brand new IE .292, not reground with IE springs for that cam, , Cam and journals weren't touched, New BMW rockers and eccentrics, shafts, Went together perfect. It may be just valve cover was surfaced for some reason, When I get a chance I'll compare to other one I have. I did measure thickness of head when rebuilding, It had been surfaced, But if I remember it was only minor amount, maybe .005
If everything else is fine, then grind away the valve cover where it's hitting, 2 gaskets will probably leak.
