Sign in to follow this
jamesnutter50
Kooglewerk DCOE velocity elbow
3 posts / 454 viewsLast Reply
Hi, can anyone tell me what parts I need to fit my kooglewerk  DCOE velocity elbows to my weber 40's
do I need studs to fit them or bolts ? What size bolts do I need ?
Regards
James
Send an email my way and I can walk you through in more detail (We Still need to take and upload a couple pictures for the website) depending on if your carbs are already installed on the manifold or not, there are a few approaches. Here is the “quick version”: Either way you’ll need to remove the upper (M6) studs on the carbs and swap/thread them into the upper threaded holes on the elbows, then clearance (drill out) the threaded holes on the carbs to accept the studs. (Tape off open carb throat first!) Then the nuts will install on the carb side. The existing bottom carb studs will slip right on the elbows & tighten up the same.  Hope that helps & please feel free to email [email protected] for more info/pics. (I’m not on here enough to respond in a timely manor)
-Forrest
Edited by Forrest_KoogleWerks
  • Like 3
